time2roll
May 11, 2015Nomad
jrnymn7 wrote:Except you started over so it is not really the end of an eight hour charge. This is not a clock spring you are winding. The electrochemical process is more varied and changing.
Smk,
Have you seen current rise at the end of a Vabs charge? It seems strange, to me.
Did you let the 9 amps continue the rest of the day? Did it continue to increase? Fully charged should get you down close to 2 or 3 amps with 4x GC2.
No I have never waited around and watched an ammeter. Only on an over discharged battery have I see amps start slow and then increase. The process is a bit exaggerated at very low charge.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
