jrnymn7
May 12, 2015Explorer
Would a loose ground on the converter or inverter cause this? There simply are no other leach loads I can think of.
And yes, I will check all connections, again, before doing the capacity test, followed by a charge. And I keep the tops very clean, and always wipe up thoroughly after doing SG readings.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
