dieseltruckdriv
Oct 14, 2021Explorer II
profdant139 wrote:
(This question is an offshoot of my question about cables to portable solar panels -- but since the subject of Anderson connectors comes up in a variety of contexts, I thought it would be better to start a new thread.)
Anderson connectors seem to be very useful for "plug and play" electrical power. I did a little research, and (of course) managed to confuse myself thoroughly.
I see that they come in various sizes. To borrow a phrase, does size matter? For example, if I am using ten gauge wire to draw power from my portable solar panel, but I choose a too-small Anderson connector, have I created a bottleneck that defeats the purpose of the heavier wire?
The obvious analogy is to a garden hose -- if you hitch a 3/4 inch hose to a half inch hose, you are going to be limited to the flow rate of the smaller hose.
Does the same limitation apply to the Anderson connector? And if so, how do I choose the right connector for the job?
Thanks in advance for your collective insights, bearing in mind that lots of us who read the Tech forum postings have little or no technical expertise.
There are two different size Anderson connectors that would be applicable to what you want to do.
First, this one.
Second, this one.
For what you are doing, I would use the second. The first (50 amp) will have a larger contact area, but unless you are very anal about getting every milliamp from your portable solar it is overkill.
If you are going to use it in wet locations, and I am not talking about the occasional rain, the Anderson connectors are not what I would choose. I wouldn't use the Zamp (SAE) connector either.
The problems with the SAE connector is one of gender, and they do not seal well. With the Anderson connectors, gender doesn't matter. With the SAE connector, if not wired with forethought, it can have power available on the exposed pin.
I use all of these connectors at work, and for my personal stuff, I use the second link. They are available in 15, 30 and 45 amp versions, and it strictly depends on wire size, that is the only difference.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
