golf_bears's avatar
golf_bears
Anderson Valve Leak???
Tried a whole bunch of things to stop the fresh water tank from filling while hooked up to RV park water supply. Replaced the spool in the Anderson valve, replaced the entire Anderson valve, thought about replacing the water pump because the check valve is probably leaking. The pump works fine and is difficult to get at to replace.
I'm thinking of getting a 12 v DC water solenoid valve and putting it on the fresh water tank fill water line. The valve is normally closed so when hooked to RV park water supply no water will get into the tank. The fill line is also the suction line for the water pump.
Thinking of putting the solenoid in parallel with the water pump on/off switch. When pump is off the solenoid valve is closed. When I need to use the pump (boon docking) and switch the pump on the solenoid valve will open and allow the pump to deliver water where needed.
The water line is a lot easier to get at and appears to be an easier fix for me.
What say you, pros or cons???
  • Dutch_12078, I also think if the check valve is on the output side of the pump, the pump's pressure gauge and trigger will never see the pressure drop in the water lines and therefore will not kick in.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
