I'm still new to this anode rod business as we've always had an Atwood water heater... So tell me - is this normal and should it be replaced now? We're afraid that it will keep getting thi...
Depending on use you can get 3-4 years out of one. Only once did I ever get a year out of one! That still has at least one probably 2 years left I it. Once you get near the metal rod (1/8” rod) then it’s time to replace it.
You want to be really shocked? Flush it out with a water hose with an attachment that has a stream. I just flushed mine and got a ton of crud out of it!
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
