aruba5er
Aug 26, 2013Explorer
Took my anode out in 2007 because it was causing water to stink. ( we were in Florida at the time). I installed a 3/4 " ball valve in it's place so I can drain it easily. 6 years and no tank troubles yet. Think about this. In your stick and brick home, after a while the anode is used up. Did you replace it? I think NOT. forgot all about it, if you even knew it was there. Same think differant size tank.
