The threads in my suburban water tank have gotten kind of corroded. I am putting a new anode rod in, but it will not turn in very far. The threads are not stripped, but need a good clean out. Does ...
The threads are tapered in, they are pipe threads. It is expected to get tight as you install it. If the threads are clean and sharp, there is no need to chase them. Just snug up the anode, pressure test for leaks, if no leaks let it be, if it leaks, tighten until the leak stops.
