vandave's avatar
vandave
Anode rod
Looking at a new class A and when they showed where the water heater door was I noticed there was not a place for an anod rod are they no longer needed?
  • Whether a water heater needs an anode rod depends on the materials used in its construction. As noted above, different manufacturers use different materials.
  • Some new rigs do not have a tank, but are continuous demand water heater.
    make and model of rig you are looking at.
  • There is always a place for an anode rod.....they go in the drain hole.
    But as noted Atwood doesn't require one even though aftermarket has them for sell.
    Anode rod is a sacrificial rod of magnesium (Suburban OEM Rod) or aluminum (Suburban Optional Rod). Suburban requires them because of STEEL Tank that is glass-lined.
    Atwood doesn't require them because of Aluminum Tank clad with zinc alloy
    Suburban water heaters require an anode rod, Atwood water heaters do not.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
