MEXICOWANDERER wrote:
What are the individual 3-cell battery readings?
Magnum Status indicated Full Charge/MidNite indicated Resting. I turned back on the Equalizing at 14.4V. We only had an hour before we needed to disconnect to move to a non powered site. At the end of that hour Amp was indicated at 22, down from 32 where it started.
B1 = 67.3 / 67.3 / 67.5
B2 = 66.9 / 64.1 / 63.1
B3 = 64.1 / 63.9 / 63.4
B4 = 66.6 / 63.5 / 63.5
All measured on the where the cap would be, the plug.
If it matters, B1 had the Positive coming in from the Magnum. B4 had the Negative coming in.
We will have power again on Saturday for one night, then back to non powered sites. So I can do a Equalize/Conditioning again at the Lifeline recommended value of 15.5 77F, if it is recommended.
Thanks,
Smitty
