MrWizard wrote:
use the meter, check volts on each battery, with engine off
start engine and check volts on each battery again
voltage should be above 13 aka 13.xx to charge the batteries
batteries getting voltage are being charged
yes autozone will check your batteries, they check mine, they like selling new batteries
Did as you advised and the only battery that stayed the same was the new one that's in front connected to the other one, by the way the rear one is a Interstate High Cell or something like that, so what do I do about the battery that remains the same?
Thanks
