fyrflie's avatar
fyrflie
Explorer III
Mar 23, 2021
Another Hot Water Heater problem
I have an 2001 Atwood 6 gallon water heater that will run one complete heating cycle then go into the lock out mode. If I shut off the switch then turn it back on, it works fine for another complete cycle then goes back into lock out.
I have replaced the control board, gas valve, thermostat, ECO, igniter, thermocouple and gas tube.
I have 12 plus volts at the board and have cleaned and confirmed a good ground.
Both the Thermostat and ECO switches check out fine with a continuity tester.
When it’s operating, the flame is text book color. I also ran a rag through the U Tube to confirm no blockage or debris.
I did notice a voltage drop in the Red wire. 12.7 volts at board and 12.3 volts at Other end. Don’t know if this matters or not but I am going to replace the connector.
I have a new regulator and manometer coming in the next day or so.
What am I missing?
Any help would be appreciated.
  • dougrainer wrote:
    What you have is what the defective boards did. Doug
    Just installed a new board and it won’t even start.
    When you turn the switch on, it goes directly to lock out. Red light goes out then it immediately comes back on.
    Could it be another bad board?
    Where are you getting the Boards? The problem Atwood had 2 or 3 years ago was they had no way to make 100% sure that the suspect boards were returned from vendors. That means dishonest people could get a hold of the suspect boards for almost nothing and then sell on the Internet or E bay. Most would work just fine a few times. We made sure we returned and purged our stock when Atwood had the problem and had Atwood send us the untainted replacement boards for our stock. You leave the switch ON. Disconnect the module plug from the board and plug in to test at the water heater. Doug
    First board came from PDX in Oregon, second board came from Amazon.
    The first board is Version D and the second is Version E. So something changed I guess.
    What are you referring to when you say “plug in to test”. What do I plug in?
    Update:
    Installed first new board, new ECO and Thermostat and new wire harness.
    Water Heater fired off and is working as designed. Going to cycle it a few times to confirm operation.
    New wire harness eliminates the small plug adapter and both the old ECO and Thermostat tested good on the bench.
    Only time will tell.
  • Ran an overnight test and the water heater failed again. It went into lock out mode.
    Domestic suggests that I take it to a service center because the chance of having multiple bad boards is very slim. Even though everything points to a bad board according to the Atwood troubleshooting guide.
    Talking to PDX Wholesale about options to get another board.
    Playing the waiting game now.
  • When the water heater works the first time before lock out, does the Pop off valve leak or seep? Doug
    No leakage whatsoever.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
