mena661
Nov 02, 2014Explorer
reed cundiff wrote:What Reed means here is that LFP (LFP=LiFePo4 is in the lithium ion "family") cells need to be "balanced". Unlike lead acid batts where each cell will balance themselves (balance = same voltage on each cell), LFP batteries can't do that. You have to perform that task manually (volt meter) or have a BMS system do that for you. The reasoning for cell balancing is you don't want to overcharge a cell. Overcharging LI batts will kill them.
There are arguments going back and forth among LFP users about using battery management systems (BMS)or close monitoring of cells with Fluke meters.
