reed_cundiff
Nov 05, 2014Explorer
If you want a lot of information on LFP battery usage, go to the Cruising Forum. There are over 100 pages of posts on LFP usage.
The simplest way of handling the voltage is from a post I just found on this forum
"...Regulated voltage control and monitoring is essential, keep any cell below 3.6v and above 2.8v so set the charging voltages and load disconnect with these in mind. I highly recommend monitoring individual cell voltages, a $28 Junsi cell logger from a hobby store is idea for this job, set the alarm voltage to the figures suggested above and you will have a warning if something goes wrong..."
Reed and Elaine
Reed and Elaine
