SMarquez's avatar
SMarquez
Another No Start Onan
I started out with a no start Onan 4000. Not even a pop. I was getting code 36. I removed and cleaned the carb as best I could. I can now get about a 5 second run and now only flashing 3. i tried to retrieve codes but only now getting 3. Fuel pump is pumping when priming but I didn't check the fuel pressure due to time.
From searching the net, I find that it is generally a fuel delivery issue and the non rebuildable carb seems to get blamed for a lot. So, is it time for a tech or do I throw a carb at it and hope for the best? I don't have a problem attempting more trouble shooting since I am a cheap bastard but just checking to see if I should cut to the chase with a shop.
Steve
