DD716TED's avatar
DD716TED
Another Surge Protector Post
Whenever I pull into a RV space, the first thing I do before plugging my travel trailer into the power pedistal is I plug a yellow device into the 30 amp outlet (using adaptor) to check for polarity / open / gound issues... when all reads well, I plug my trailer into the 30 amp receptical... I am looking at a 2000+ Joules surge protector from CW... No over / under voltage protection but I seldom if ever use my Air Conditioner.. Only use a TV / Satellite receiver / refrigerator / power converter panel when plugged in. Is the over / under voltage protection / time delay feature offered by the more expensive Progressive Industries EMS system really needed when my uses are minimal and just looking for surge protection? Comments??
  • Hi,
    103 is too low for the cut off. At that level damage is accumulating in the electric motor(s) of the air conditioner.
    Are you sure it is 2 minutes? I thought it was 3. 2 is not quite enough for the head pressure to bleed off.
    My own comfort zone is 108 volts.
    HappyKayakers wrote:
    Get the PI EMS and enjoy your stay. It will cut off power to your RV for several different dangerous situations, wait 2 minutes, then reestablish power if it's safe.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
