NaturalStateReb's avatar
Feb 10, 2015
Antenna Booster Problem
I'm having an antenna booster problem that's got me baffled. The green light on the antenna booster wasn't lit, so ordered a new booster for my 2009 Keystone Summerland. Got the Winegard wall plate booster installed, still no green light, and no antenna signal either.
Checked the fuses, they're ok. Got out the multimeter. Leads are appropriately installed and I get a 12v reading. When I push the booster switch, and put the positive test lead in the center of the antenna coax coupling, and the negative lead on the outside, I get 1.75v. No light.
I guess it's possible I got a bad booster delivered, but seems unlikely. This camper doesn't have additional cable outlets, so I don't think there are any splitters in the unit. I'm at loss. Anyone got any ideas?
  • CA Traveler wrote:
    Are you sure the coax cables are not reversed? Remove the antenna coax and if the voltage is 12V then you might have a short. Next step would be to measure the current which should determine bad booster or short.
    Run a temp coax out the window and up to the antenna to help isolate the problem.
    Ditto: Original problem could be a shorted coax. Disconnect the coax at both ends and use an ohmmeter to check it. If that is ok then reconnect the coax at the power inserter end and measure at the antenna end with the coax disconnected. If you have good 12 volts then reconnect and check. If the voltage drops your antenna has a short inside. The amplifier is in the head of the antenna.
  • Just for giggles, unhook the ant and see if the voltages come back.
    Never seen it happen in a RV but was common on aircraft.
  • Are you sure the coax cables are not reversed? Remove the antenna coax and if the voltage is 12V then you might have a short. Next step would be to measure the current which should determine bad booster or short.
  • Sounds like a lot of work. One bet, though, its is probably something pretty simple, just hard to fine.
Having RV issues? Connect with others who have been in your shoes.24,342 PostsLatest Activity: Dec 11, 2025
