dougrainer
Mar 01, 2020Nomad
Cummins12V98 wrote:
Behind Access panel to my shower valve is where mine WERE as in no longer there! Leakin SOB’s are long gone with PVC fittings in their place.
They are installed to prevent holding tank ODOR from venting out the inlet fitting. Most BT flush inlets do NOT have a check valve like the City Water inlet because of the inside Check valve. If the OP's is NOT factory installed, then there is no upper Check Valve. The INLET and the inlet to the tank has a check valve, that comes with the aftermarket BT kit. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
