Cummins12V98
Mar 01, 2020Explorer III
dougrainer wrote:Cummins12V98 wrote:
Behind Access panel to my shower valve is where mine WERE as in no longer there! Leakin SOB’s are long gone with PVC fittings in their place.
They are installed to prevent holding tank ODOR from venting out the inlet fitting. Most BT flush inlets do NOT have a check valve like the City Water inlet because of the inside Check valve. If the OP's is NOT factory installed, then there is no upper Check Valve. The INLET and the inlet to the tank has a check valve, that comes with the aftermarket BT kit. Doug
They are check valves on the grey and black tank flush lines. They are there to keep contaminated water from siphoning into the public water supply.
Holding tanks vent thru the roof!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
