bigfootford
Aug 29, 2020Nomad III
Well there is a cog in the wheel...
25 amp max charge rate!
https://azimuthsolarproducts.com/product/12v-100ah-sio2-battery/
Battery Type
SiO2 Composite Electrolyte Battery
Nominal Capacity (25°C/77°F)
100 Ah (1.2 kWh) @ 20 Hour
Nominal Voltage
12V
Max Charge Current
25A
Max Charge Voltage
14.7V
Internal Resistance (25°C/77°F)
=< 6.8 m?
Max Discharge Current (25°C/77°F)
900A(5S)
Depth of Discharge
100% DOD
Operational Temperature
-40?C to 65?C (-40?F to 149?F)
Self Discharge
< 1.6% per Month
Life Cycle
3400 Cycles at 40% DOD; 1500 Cycles at 80% DOD; 620 Cycles at 100% DOD
Dimensions
16.8 x 30.7 x 21.5 cm (6.61 x 12.08 x 8.46")
Weight
27 kg (59.5 lbs)
Battery Type
Nominal Voltage
12V
Max Charge Current
25A
Max Charge Voltage
14.7V
=< 6.8 m?
900A(5S)
Depth of Discharge
100% DOD
Self Discharge
< 1.6% per Month
Life Cycle
Dimensions
Weight
27 kg (59.5 lbs)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
