Wayne_Dohnal
Aug 23, 2013Explorer
If the temperature is lower for the 2nd measurement that will account for part of the voltage loss. You probably don't have a short circuit. What you're suspecting is often called a "phantom load". IMO the easiest way to start looking is to have everything you know about shut off, then one-by-one pull the 12 volt fuses and bridge the fuse holder contacts with an ammeter. A multimeter with a 10 amp range is good for this. This tells you which circuits are pulling power, after which narrowing it down further can get more complicated. Measuring battery SOC with a voltage measurement is approximate at best, and requires interpretation based on the the recent charging, load, and temperature situation.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
