westend
May 31, 2014Explorer
I've used the water spray trick for finding a bad pulley. I actually have a can of belt spray to use for this. One problem with the spray is that the tensioner pulley is fully capped on the 5.4 and is mounted onto a bracket, attached to the engine. You could put a stream of water onto it and it won't hit the bearing surface or shaft of the pulley.
Getting a garden hose on the pulleys to use a stethoscope or even a stethoscope would be difficult with my truck. There is not a whole lot of space in there.
A tensioner pulley bearing failure is easily diagnosed by removing the belt and rotating the pulley by hand.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
