So thought I would give an update......
Finally got my slide all "straightened" out! I eventually lifted both inner rails and was able to disengage the gear pack. I could not push the slide in though so got an RV guy to come help. Long story short.....some of the adjusting bolts were loose, so over time, each time I put the slide in and out it was moving out of adjustment a little bit at a time and till finally.....way out!
Needless to say, I consider myself now VERY knowledgeable on through frame slides!! So if any of you need help with one let me know.
