campermama's avatar
campermama
Explorer II
Aug 01, 2022
Any Words of Wisdom?
If any of you saw my post about my slide.....
Sooooo this is what happened!!
The reason this happened is the seal on the motor side somehow got stuck to the caulking on the slide, no idea why this would happen! So the motor side was stuck when I attempted to extend the slide not knowing it was stuck but then it broke free and the slide extended out.
So I think.....it is the motor side that jumped 3+ teeth (118.5 showing now) when it broke free.
I'm now thinking the motor side is the side I need to adjust (push slide in) to match passive side. Does this sound right? More I think about it the more sense it makes to me.
Passive side is showing 115 teeth.
I am going to attempt this on Wednesday. There is actually an access door to the motor underneath. Not sure what motor is down there but hope it is easy to disengage the gear. Then I will need to push that side of the slide in about 3 teeth worth. This slide is about 10' and holds the recliners and a table with 4 chairs.
Here is where I need your wisdom. Has anybody done this? Will I be able to push the slide in myself?
Thanks all! Oh, this is a through the frame slide, 2 rails with teeth on the bottom. It is NOT a in the wall schwintek!
  • cj99 wrote:
    yes and they are : dont buy a RV
    Yes and they are?? Thanks for the help :(
  • Came up with another idea from some forum guys....I'm thinking I can disconnect passive side of the drive rod then slightly move the motor side with the motor. I'm just a little worried about getting the holes to line back up to reconnect drive rod.
    But this seems the easiest way to do this since the drive rod is in the enclosed underbelly. Thoughts???
  • ferndaleflyer wrote:
    It won't help you but my Monaco has a built in winch and strap mounted in the storage bay to pull in the slide if for some reason it don't work as it should. Its just another of the little perks of a high end DP.
    That's great! Yeah I have some ideas (jack related) if I am not able to push it in myself ;)
  • It won't help you but my Monaco has a built in winch and strap mounted in the storage bay to pull in the slide if for some reason it don't work as it should. Its just another of the little perks of a high end DP.
  • I did this years ago with my big slide that has drive gears on two rails. I remember having to loosen the gear drive on one side so the other rail would move independently to re-align it, then tightened the loose gear to match. My slide is way too heavy to be pushed, but I did need a helper to activate the motor.
    I don't know if your setup is the same.
