Almot
Jul 08, 2016Explorer III
DAS26miles wrote:
I see that the ABS stickon mounts come with side spoilers.
I hope you don't mean ABS mounts for panels. Plastic mounts isn't a good idea, and so is anything stick-on. Some people had luck with sealant-only on fiberglass roofs, no screws, but screws are better.
Use aluminum brackets and stainless fasteners.
Speaking of hurricanes... Left my trailer in Mexico for hurricane season. After the hurricane homeowners gringos were talking that solar is such a pain, panels flew off the roof again, etc etc. I was like, - "what"? This can really happen? :)
1/4" thick aluminum bracket on each corner, 5 screws per bracket, half of them in rafters, Dicor under brackets. Darn thing will survive the trailer. Could've used a thinner metal but needed 4x4" angle to clear the vents, angle that big doesn't come in 1/8". Overkill, I know. Initially designed to sustain sudden 40 mph winds when TILTED - imagine the forces on 250W panel. Flat array generates enough power though. No tilting for me.
Off the shelf brackets are often flimsy.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
