jesse_m_jm's avatar
jesse_m_jm
Anyone plumbed in a Washer/Dryer w/o your rig pre-prepped?
We bought a Splendide of Craigslist at a big discount(looks like it was never even used), and when I got a quote for prep in our TH, I was told around 1k.... so I am hoping I can do it myself. I just wondered if anyone else has done it and has any pointers. I understand these systems fairly well, but it never hurts to ask.
Thanks,
Jesse
  • The only reason I mention a vent line on washer drain line is due to the washer pumping water into grey tank. Flow rate maybe greater than grey tank vent can handle.
  • Old-Biscuit wrote:
    Have to run hot and cold water lines
    Have to run a drain line to grey tank
    Have to run a vent line on drain line so washer can drain
    Have to run 110V AC power
    Have to run dryer vent
    About $1k.....sounds about right
    Hey Biscuit,
    The only one I'm not clear on in your list is run a vent line on drain line. Do I just need to tie it into one of the other vents that goes up to the roof? Sorry if it's a dumb questions, a vent line just wasn't one of the items on my list. I assumed the grey was already vented so I didn't need to.
  • Have to run hot and cold water lines
  • Depending on where it is, I would think the worst part may be dropping the cover on the bottom of the rig and plumbing in the drain. Unless it's right next to a sink - then it should be easy.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
