- pianotunaNomad IIIReally not too suitable for an RV as it is intended for grid tied and 240 volts AC. The $3000.00 cost does NOT include the inverter. It appears that the inverter is another $3000.00. By the time tax is paid we are at $1.00 per watt for this storage solution.
Further the voltage for the actual powerwall output from a dc to dc converter is between 350 and 400 volts.
It would seem to me that going for a 48 volt LI solution would be considerably cheaper. Stand alone cells are available at up to 1000 amp-hours @ 2.6 to 3.8 volts volts. 13 cells @ 400 amps would do 48 volts nicely. A good battery management system is needful given the cost per amp-hour.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
