stargirl96's avatar
stargirl96
Apollo microwave
We have a 2007 Winnebago Outlook with an Apollo microwave/convection oven combination. The microwave has ceased working. The only keypad button that works is "reset." I've read in forums that they don't make this oven, and you can replace it with a regular microwave. But, I don't even see how to get it out of the housing. The stainless steel cover over propane burners and microwave keypad seem to be one unit.
  • I plainly see two screws at the top of the shroud and two intentions at the middle and bottom that certainly are screw access as well. With all due respect, if you cannot see that and start removing screws from there, you probably lack the skills to do a replacement. Good luck to you, but you need to find someone to do this job for you.
  • learn how to post a photo here
    https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/15775751.cfm
