Gjac
Jun 10, 2017Explorer III
I looks like it is #6 in the parts diagram, having said that the blade seal that you are taking about probably has a build up of mineral deposits that is causing it to hang up on the blade seal. If you camper is a 1990 the blade has had 27 years to build up deposits. Mine was 20 years old when I had to remove the toilet and disassemble the unit to scrape off the deposits. It is not a difficult job.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
