Gjac
Jun 11, 2017Explorer III
pasusan wrote:I posted in error I meant to say the blade itself gets a mineral deposit on it not the seal.Gjac wrote:Thanks - yeah, I did replace both the seals on the 1990's toilet. :)
I looks like it is #6 in the parts diagram, having said that the blade seal that you are taking about probably has a build up of mineral deposits that is causing it to hang up on the blade seal. If you camper is a 1990 the blade has had 27 years to build up deposits. Mine was 20 years old when I had to remove the toilet and disassemble the unit to scrape off the deposits. It is not a difficult job.
This time it's for the 2004 Roadtrek and the seal seems OK for now - it's the blade assembly that doesn't work properly.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
