Sooner_Schooner's avatar
Sep 07, 2015
Arctic Cold cooling unit review
Have any of you changed out your cooling unit for the new "Arctic Cold" brand? If so, what are your opinions of the refrigeration unit?
  • islandvagabonds wrote:
    I highly recommend the Amish replacement units from RVCoolingunit Warehouse. I put one on my Norcold 1200 two years ago. Works better than the original unit. make sure you install the internal fan kit at the same time. Fridge works almost like a residential unit now.
    Have not heard of the Amish unit before, I will check it out, Thank you.
  • I highly recommend the Amish replacement units from RVCoolingunit Warehouse. I put one on my Norcold 1200 two years ago. Works better than the original unit. make sure you install the internal fan kit at the same time. Fridge works almost like a residential unit now.
  • Replaced my Dometic fridge( almost 25 years old) with a new exchange unit from them last year. It was a newly manufactured unit, fit ok with only minor adjustment issues. The cooling tube at the top of unit was bent slightly in transit( Articold says it may happen in their literature) easily reset. Unit been running great, no problems. They have a toll free number and will answer any question you have. I am satisfied with unit so far
    Jeff
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
