BFL13
Aug 31, 2021Explorer II
Baja Man wrote:BFL13 wrote:
OP is asking about plugging into gens, but the two receptacles are in the paraLink.
The neutral-grounding plugs I am referring to are plugged into the inverters 120V receptacle
I have seen the bonded 15a adapters used for that and you would have one on the shore power cord plug. You say you will be using the parallel kit, so you will be plugging into one of the two 30a paraLink receptacles depending on your plug type, not into one of the gens.
Do you intend to have a 30a adapter modified to be bonded? Very confusing.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
