wa8yxm
Sep 01, 2021Explorer III
As I understand it the parallel link has only two wires to each generator. Thus you will need to bond at the 30 amp outlet in the P-link. Easiest way (if said assembly is not molded) is to open the outlet assembly and add a jumper.. Just make sure you jumper the PROPER (Neutral/Ground) pins.
Actually with inverter generators the Surge Guard is not needed so you an use the bypass mode safely.
But there is still a good reason to bond.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
