Sep 01, 2021Explorer II
You need only 1 plugged into either genny. This will bond the yellow/green wires to either the red or black wires on both gennys. I don't know which is neutral.
You can verify this by plugging your bonding plug into either genny and measure resistance from the ground to neutral on either receptacle on the paralink. It should measure close to 0. Unplug your bonding plug and resistance should go high. All this with it powered Off of course.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
