Sep 01, 2021Explorer II
wnjj wrote:I just verified this on all four of my Champions, one being an inverter model. The receptacle ground prong is tied to the external ground lug on all of them. He will connect the yellow/green striped ground wire to the ground lug and plug a bonding plug into any receptacle on either generator. This will bond ground to neutral on all receptacles. You want to bond at only 1 point.BFL13 wrote:
In the link for the Link it shows the yellow wires going to each gen's chassis ground lug.
How does the chassis ground for the gen connect to the gen's receptacles' neutrals by using the bonding plug unless the gen's chassis is connected to the receptacles' grounds?
Is that what wnjj meant above?
Yes, the ground pins on the 20A receptacle are connected internally to the ground lug, which is where you attach the parallel kit ground.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
