Cummins12V98
Oct 19, 2018Explorer III
camperguy99 wrote:
Unless you have increased the wire size from the truck to the 5th wheel I doubt if you are actually doing ANY charging going down the road. Between the frig and current draw of the even unloaded inverter could eat up all the available current from the trucks alternator. Been there done that. I had to parallel additional 10 ga wire from the truck back to the 5th wheel battery bank. Before about 7-8 amps, after greater than 20 amps. A clamp on current probe would answer all the questions.
As I mentioned up until this trip the frig stayed right on 0 and 38. It stayed that way on a continuous trip of over 30 hours. The truck does keep the batteries charged. The 1,000 watt inverter does a fine job also. I am convinced the batteries at 4 years are the issue.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
