Cummins12V98's avatar
Cummins12V98
Explorer III
Oct 19, 2018
Are my Batteries going bad?
My two 6V Batteries were installed in my DRV in early 2015 when new. They have no labeling to tell brand. I would guess they are 4 years from mfg date or even older now.
Normally I can drive for 10 hours or longer and when I stop the residential frig is 0 degrees freezer and 38 on top. I have a 1,000 watt inverter and yes it was on. This trip the freezer was the same but the top was 43 degrees. I checked the water before leaving and it was full. I checked the battery voltage and it was 11.5V.
Thoughts?
  • our 4 batteries were new in Oct of 09 replaced in Dec of 14. Now it is 18 and I will be watching them and new will be installed. Batteries are the same thinking I have about tires. Earlier is better than later. have a great winter everybody. We are hitting the road tomorrow for Az one month later this season.
    chevman
  • Yes the truck is supplying power to the RV while towing. I drove 30+ hours from SoCal to DFW TX and the frig was at 0 and 38 upon arrival, this was about 10 months ago.
    So I am thinking the batteries are being sucked dry faster than they can charge because they are getting tired.
    I agree 4 years is a long time for RV batteries especially no name.
    Just thought I may be missing something.
  • Start the vehicle and then measure the battery voltage. IF the voltage goes up to 13.5 or more then you know the charging system is functioning, however the connections on the batteries must be spotlessly clean.
    That said, four years is plenty on unknown batteries. A hydrometer and load test would help but you already did a load test by running the refer. Lots of little unknowns here but one does not BUY batteries, we just rent them.
    If you use hookups mostly you can nurse more time out of the batteries but it is not worth the hassle. Too many things rely on good batteries.
  • At 11.5 volts the battery is about dead. Is charging voltage being supplied to the battery while under way?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
