time2roll
May 16, 2019Nomad
Very common for the 'multistage' WFCO to just charge at a fixed 13.6 volt trickle charge. Mostly OK for just plugged in.
I would turn the converter off and just use the solar full time. Actually this is what I have been doing since I installed solar. If solar does not keep up and your battery is sagging close to 12.0 or 12.2 then turn the WFCO on 24 hours for a boost.
There are better converters if you are inclined to spend the money. Well worth it if you expect a fast charge from a generator.
