RoyB
Nov 09, 2015Explorer II
The 'click' 'click' usually means battery not up enough to crank it. If it is 12VDC jump it with the truck battery cable and get it started again... Then using a multimeter find out about how you need to keep the battery charged up when sitting for a long time... Add a trickle charge from some source. Even one of those low wattage solar things might work out for you. I have a 9 WATT small panel sitting in my truck windshield area. I wish it had more watts like maybe 12-15WATTs because my truck has too many parasitic drains. Your generator probably doesn't have much parasitic drains...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
