T_bone1's avatar
T_bone1
Explorer II
Jun 06, 2017
ATS question
A few days ago I started the generator and started the front a/c and all was well.Started the rear a/c and it ran for about 3 minutes and both quit.Started hearing a clacking noise from the rear.. Got out to look it over and discovered the ATS was kicking. I pressed the bar in the ATS and the generator started to load up,when I released it the generator unloaded..I am wondering what the deal is.. Any help is appreciated.I posted on Forest River forum and got no response..Thanks for your time!!
  • Ran it again yesterday and it all worked well.Who knows how it will act next time.
  • T bone wrote:
    it is showing 123 volts no load
    Perfect. Now what is the voltage with one running and then two A/Cs running?
    Low voltage will cause the TS to drop out. And it could be defective. So manually engage the switch as you did before while you monitor voltage. Anything much below 110 is low. Do give it a few moments to stabilize after start up.
  • "It will run 1 a/c fine. "
    Sounds like the contacts may be damaged enough(burned) that it can't pass the rated current unless you hold it closed.
    By "kicking" do you mean turning on and off?
  • T bone have you checked the output voltage when the genny is running?
    I generally hate transfer switches. They should never be used when "under load", so I don't see their advantage over a simple system of male and female plugs.
  • check the generator voltage
    if its ok, then the ATS has died, and its time to replace it
  • First guess is relay is bad.
    Can you get a make and model number off the switch?
    Second guess is voltage off generator is to low to hold in switch.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
