Almot
Jan 03, 2016Explorer III
DrewE wrote:
{alarm} will work fine because the resistance of the alarm is much much higher than that of the fuse, and so the high current will not flow through the alarm--it will be limited to whatever the alarm usually uses. It's no different than connecting the alarm directly to the battery.
If alarm is in parallel to the big fuse that is sitting on the Pos terminal - as it was suggested - then whatever high current flows through the big fuse and blows it, will flow through this alarm a moment later.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
