pugslyyy
Feb 10, 2015Explorer
I'm assuming that your other gas appliances are running fine so you know you are getting good gas supply to the furnace.
You should be able to look at the circuit board on the furnace and read the error code, it will be a blinking LED and you count the number of blinks.
Good luck!
Good luck!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
