1fastdad
Feb 10, 2015Explorer
This is not a problem if there is nothing blocking the heat vents. They have a thermal switch that prevents the firebox from overheating. Depending on how the air ducts are run some units do this and others don't. If you shut off a vent or block them in an attempt to direct heat to an area of the MH it will do this.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
