brulaz
Feb 12, 2015Explorer
pugslyyy wrote:
I'm assuming that your other gas appliances are running fine so you know you are getting good gas supply to the furnace.
Even with the other appliances working ok, the Propane regulator on the tanks may not be giving as much pressure as the furnace needs. At least that's what happened with ours. Guess the furnace uses a lot more propane than the other appliances.
Worked fine with a new regulator.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
