enblethen
Nov 17, 2019Nomad
Go to the furnace, locate the two blue wires. Connect them together. This should start the furnace fan, within short period 10-20 seconds the furnace should produce heat.
If nothing happens verify 12 volts DC to furnace. No power, probably fuse.
Power but no fan check small circuit breaker mounted on fan housing.
Fan comes on but no heat, blow the furnace out, paying attention to the sail switch area.
