climb_on
Nov 17, 2019Explorer
enblethen wrote:
Before replacing the thermostat, again, Locate the furnace output from the thermostat. Should be same blue wires as in furnace. Connect them together and test.
Not sure what you mean by furnace output. All the wires from the thermostat go up to the relay board area in the air conditioner. It's hard to follow things up there. So the wires at the thermostat are not the same as the wires down in the furnace.
I should be able to jump two wires at the thermostat though...furnace and power wire?
Thanks so much for all your suggestions by the way... I really appreciate it.
