dougrainer
Nov 17, 2019Nomad
Old-Biscuit wrote:dougrainer wrote:climb.on wrote:
It seems like this narrows it down to the relay or the wire between the furnace and the relay. No idea how to trouble shoot the relay. No Duo-Therm relay board with the part number 3107541.009 seems to be available.
This is a problem when you have no idea what you are doing. That P/N is for a Analog DOMETIC control kit. That is the Module in the housing and the wall tstat with the AC mount bolts. 3106996.022 should be the analog module only. FYI, NOBODY says Duo Therm. That term has been obsolete for over 35 years. DOMETIC is the Brand name that is used. Doug
You information would be so much better received if you were NOT so condensending in your relies.
Lighten up....good grief
READ all his posts. He has NO CLUE what he is doing. I am Blunt. Better to be blunt than have him follow all the nonsense posts on this thread. Sometimes people need to be clued in when they need more help than they can understand. Doug
