climb_on
Nov 17, 2019Explorer
enblethen wrote:
Start checking area around the wire entrances for physical damage. Do it at both ends.
Try routing a wire to test which one is open. Makes it a little easier.
Wiring maybe exposed in some void areas like behind converter or in refer outside access.
Will do. Thanks for all your help, ideas & suggestions. Will follow up as I get it worked out.
