enblethen wrote:
Hopefully your computer can't read and yours is an 8520. What is series II,III or IV?
You were right, that by the time I walk from the camper to computer, I scrambled the number.
It is 8520 series IV
I took it apart and had small insects everywhere, but I believe those are still from Minnesota where I bought the camper 3 years ago.
Check the gas pressure and 3 burners on cooktop would not even blink when I started WH, so I assumed it had to have good pressure.
Washed circuit board and no kudos.
So finally start taking the furnace apart. Took some observation how to do it, so here are the pictures in case somebody has to do the same.
____________________________
After taking the cover off, you need to take off the wing nut visible on the center of the picture slightly to the right.
Than in twisting motion, pull the exaust pipe out. Mine wasn't to badly corroded, but that might be hard part.
Disconnect gas tubing. The bottom of the compartment has rubber seal, so I could push the tubing down for burner removal.
Burner assembly is hold by 3 screws with 1/4" hex head. One is above exhaust pipe, one you can see below the valve and 3rd one is next to #2
This is the design where igniter and probe is the same thing. The thinner wire is ground. Lot of corrosion on wire mesh and some dead insects inside.
Wire brushed the screen and blow the insects away.
Clean burner goes back. Did the test and the flame stays on.
I clean everything, but my conclusion is that the rust on the burner screen made the flame too small and flame probe was not getting hot enough.
Now I noticed, that the furnace is circulating camper air against steel cover. That has to lead to pretty good heat loss, so here is my improvement.
Thank you all guys for ideas.
