enblethen
Mar 06, 2016Nomad
Sounds like the flame sensor has issues.
Clean the furnace area out good. I use compressed air.
On the right side is the ignitor and flame sensor, make sure they are clean and adjusted correctly.
Locate the circuit board. Remove it and clean the multi-wire connector. It is good to put some electrical de-oxidation grease on the contacts before reinstalling.
Just saw you post about cleaning with long screw driver. Not good! You probably knocked flame sensor out of position.
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 10, 2026
