enblethen
Nov 27, 2015Nomad
Could be a failing thermostat.
Remove the cover, locate the two wires going to the furnace. Connect them together, the furnace should start and produce heat after short time delay(10-15 seconds). It should produce heat until you separate the two wires, then go into cool down mode and shut off. If this happens, it is a bad thermostat.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
